Losing connection occasionally
I have submitted some diagnostics, I am seeing this error every couple of days or so. I have only noticed it on trutv up until now. Today I had an issue with tnt as well.
My streaming device is a fire stick, with tuner sharing on. The error posted below is from my nas with an Ethernet connection to the internet.
Has anyone seen this issue and / or do my diags show anything?
2023/08/07 16:40:51.982962 [TNR] Error during live stream for ch6036 TNTP: failed after 38.429688589s: hls: temporary failure while downloading: hls: timeout while waiting for data
The network's server did not respond in a timely manner when requesting segments for the stream. It could be
  • a local network issue between your DVR server and your router,
  • a network issue with your ISP,
  • an issue with the network's server,
  • or any combination of the these.
Most likely, it's a temporary issue with the network's server, and restarting the stream might be all that is required.
Thanks for the reply.
After a long battle with this issue, I finally have it solved. This case can be closed.
I'm curious what was your fix? I'm dealing with this as well
Sorry I don't recall exactly what I did (other than switch to apple tv 4k box.. that might have been it).
