Loss of Food Network from Philo
I notice the posts on this issue with the Discovery Channels goes way back but nothing I have seen so far has fixed the issue. This morning my wife lost her Food Network Channel. It came up with the error 403 forbidden access. I tried everything I could think of to get it back but things got worse and like the others said the channel no longer shows up at all. I went to the server and it has the error "no login form found". The fix was to edit and rescan that channel but that has failed to work. The stopping services and rebooting, dumping cache has not helped. The only fix I saw and have not tried is the VPN trick and I’m not sure how to do that on my Synology box. Any ideas? Please help. Thanks Sheldon
You need to select Update Password on your Philo source, or remove and readd it.
Thank you so much!
