Is there an easy way to get it back or probably need to reposition my antenna that is mounted on the balcony of my apartment? I didn't have the best Signal Strength or Signal Quality percentage but it worked fine. Had a few pixilation's here an there but nothing crazy.
It's a ClearStream MAX-V UHF VHF Indoor Outdoor HDTV Antenna with a USA LTE Filter plugged into the HDHomeRun Quarto Connect.
