Lost TVE Channels
I lost access to my TVE anywhere channels starting around 4pm on Friday. I just noticed it this morning when I went I noticed that last night's episode of Mr. Robot didn't record. When I tried tuning to any of my TVE anywhere channels, I'd get an onscreen error of "Tuner not found" (or something like that--my memory is shit and I've forgotten the exact verbiage, haha.)
Checking the logs, I see hundreds of connection refused lines like:
'2019/10/25 16:11:41 [ERR] Failed to fetch station 59337: Get http://data.tmsapi.com/v1.1/stations/59337?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp: lookup data.tmsapi.com on [::1]:53: read udp [::1]:53792->[::1]:53: read: connection refused
2019/10/25 16:11:41 [ERR] Failed to fetch station 59337: Get http://data.tmsapi.com/v1.1/stations/59337?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp: lookup data.tmsapi.com on [::1]:53: read udp [::1]:53996->[::1]:53: read: connection refused
2019/10/25 16:11:41 [ERR] Failed to fetch station 59337: Get http://data.tmsapi.com/v1.1/stations/59337?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp: lookup data.tmsapi.com on [::1]:53: read udp [::1]:51669->[::1]:53: read: connection refused
2019/10/25 16:11:41 [ERR] Failed to fetch station 59337: Get http://data.tmsapi.com/v1.1/stations/59337?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp: lookup data.tmsapi.com on [::1]:53: read udp [::1]:48760->[::1]:53: read: connection refused
2019/10/25 16:11:41 [ERR] Failed to fetch station 61340: Get http://data.tmsapi.com/v1.1/stations/61340?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp: lookup data.tmsapi.com on [::1]:53: read udp [::1]:33337->[::1]:53: read: connection refused
2019/10/25 16:11:41 [ERR] Failed to fetch station 61340: Get http://data.tmsapi.com/v1.1/stations/61340?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp: lookup data.tmsapi.com on [::1]:53: read udp [::1]:36523->[::1]:53: read: connection refused
2019/10/25 16:11:41 [ERR] Failed to fetch station 68796: Get http://data.tmsapi.com/v1.1/stations/68796?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp: lookup data.tmsapi.com on [::1]:53: read udp [::1]:42380->[::1]:53: read: connection refused
2019/10/25 16:11:41 [ERR] Failed to fetch station 68796: Get http://data.tmsapi.com/v1.1/stations/68796?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp: lookup data.tmsapi.com on [::1]:53: read udp [::1]:38412->[::1]:53: read: connection refused
2019/10/25 16:11:41 [ERR] Failed to fetch station 32645: Get http://data.tmsapi.com/v1.1/stations/32645?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp: lookup data.tmsapi.com on [::1]:53: read udp [::1]:41162->[::1]:53: read: connection refused
2019/10/25 16:11:41 [ERR] Failed to fetch station 32645: Get http://data.tmsapi.com/v1.1/stations/32645?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp: lookup data.tmsapi.com on [::1]:53: read udp [::1]:40051->[::1]:53: read: connection refused
2019/10/25 16:11:41 [ERR] Failed to fetch station 16829: Get http://data.tmsapi.com/v1.1/stations/16829?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp: lookup data.tmsapi.com on [::1]:53: read udp [::1]:47292->[::1]:53: read: connection refused
2019/10/25 16:11:41 [ERR] Failed to fetch station 16829: Get http://data.tmsapi.com/v1.1/stations/16829?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp: lookup data.tmsapi.com on [::1]:53: read udp [::1]:58582->[::1]:53: read: connection refused
2019/10/25 16:11:41 [ERR] Failed to fetch station 16829: Get http://data.tmsapi.com/v1.1/stations/16829?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp: lookup data.tmsapi.com on [::1]:53: read udp [::1]:55651->[::1]:53: read: connection refused'
And then the following during the failed recording:
'2019/10/28 01:57:40 [SYS] Error checking for update: Get https://channels-dvr.s3.amazonaws.com/latest.json: dial tcp: lookup channels-dvr.s3.amazonaws.com on [::1]:53: read udp [::1]:38076->[::1]:53: read: connection refused
2019/10/28 02:00:00 [DVR] Starting job 1572228000-11 Johnny Carson on ch=[33.2]
2019/10/28 02:00:00 [TNR] Opened connection to 1077426D for ch33.2 Antenna
2019/10/28 02:00:00 [DVR] Starting job 1572228000-27 Mr. Robot on ch=[6052]
2019/10/28 02:00:00 [DVR] Waiting 1h29m59.600549137s until next job 1572233400-12 CBS 11 News at 10PM
2019/10/28 02:00:00 [DVR] Recording for job 1572228000-11 from 1077426D ch33.2 into "TV/Johnny Carson/Johnny Carson 1975-10-28 2019-10-28-0200.mpg" for 1h29m59.987968798s
2019/10/28 02:00:00 [ERR] Failed to start stream on channel 6052 via TVE-Dish: TVE: Post https://sp.auth.adobe.com/adobe-services/authorize: dial tcp: lookup sp.auth.adobe.com on [::1]:53: read udp [::1]:52135->[::1]:53: read: connection refused
2019/10/28 02:00:00 [DVR] Error running job 1572228000-27 Mr. Robot: could not start stream on channels=[6052]: TVE: Post https://sp.auth.adobe.com/adobe-services/authorize: dial tcp: lookup sp.auth.adobe.com on [::1]:53: read udp [::1]:52135->[::1]:53: read: connection refused
2019/10/28 02:00:00 [IDX] Generating video index for job 1572228000-11
2019/10/28 02:00:30 [DVR] Starting job 1572228000-27 Mr. Robot on ch=[6052]
2019/10/28 02:00:30 [DVR] Waiting 1h29m29.274511693s until next job 1572233400-12 CBS 11 News at 10PM
2019/10/28 02:00:30 [ERR] Failed to start stream on channel 6052 via TVE-Dish: TVE: Post https://sp.auth.adobe.com/adobe-services/authorize: dial tcp: lookup sp.auth.adobe.com on [::1]:53: read udp [::1]:54400->[::1]:53: read: connection refused
2019/10/28 02:00:30 [DVR] Error running job 1572228000-27 Mr. Robot: could not start stream on channels=[6052]: TVE: Post https://sp.auth.adobe.com/adobe-services/authorize: dial tcp: lookup sp.auth.adobe.com on [::1]:53: read udp [::1]:54400->[::1]:53: read: connection refused
2019/10/28 02:01:00 [DVR] Starting job 1572228000-27 Mr. Robot on ch=[6052]
2019/10/28 02:01:00 [DVR] Waiting 1h28m59.202333245s until next job 1572233400-12 CBS 11 News at 10PM
2019/10/28 02:01:00 [ERR] Failed to start stream on channel 6052 via TVE-Dish: TVE: Post https://sp.auth.adobe.com/adobe-services/authorize: dial tcp: lookup sp.auth.adobe.com on [::1]:53: read udp [::1]:59054->[::1]:53: read: connection refused
2019/10/28 02:01:00 [DVR] Error running job 1572228000-27 Mr. Robot: could not start stream on channels=[6052]: TVE: Post https://sp.auth.adobe.com/adobe-services/authorize: dial tcp: lookup sp.auth.adobe.com on [::1]:53: read udp [::1]:59054->[::1]:53: read: connection refused
2019/10/28 02:01:30 [DVR] Starting job 1572228000-27 Mr. Robot on ch=[6052]
2019/10/28 02:01:30 [DVR] Waiting 1h28m29.138716741s until next job 1572233400-12 CBS 11 News at 10PM
2019/10/28 02:01:30 [ERR] Failed to start stream on channel 6052 via TVE-Dish: TVE: Post https://sp.auth.adobe.com/adobe-services/authorize: dial tcp: lookup sp.auth.adobe.com on [::1]:53: read udp [::1]:55495->[::1]:53: read: connection refused
2019/10/28 02:01:30 [DVR] Error running job 1572228000-27 Mr. Robot: could not start stream on channels=[6052]: TVE: Post https://sp.auth.adobe.com/adobe-services/authorize: dial tcp: lookup sp.auth.adobe.com on [::1]:53: read udp [::1]:55495->[::1]:53: read: connection refused
2019/10/28 02:02:00 [DVR] Starting job 1572228000-27 Mr. Robot on ch=[6052]
2019/10/28 02:02:00 [DVR] Waiting 1h27m59.06899061s until next job 1572233400-12 CBS 11 News at 10PM
2019/10/28 02:02:00 [ERR] Failed to start stream on channel 6052 via TVE-Dish: TVE: Post https://sp.auth.adobe.com/adobe-services/authorize: dial tcp: lookup sp.auth.adobe.com on [::1]:53: read udp [::1]:50996->[::1]:53: read: connection refused
2019/10/28 02:02:00 [DVR] Error running job 1572228000-27 Mr. Robot: could not start stream on channels=[6052]: TVE: Post https://sp.auth.adobe.com/adobe-services/authorize: dial tcp: lookup sp.auth.adobe.com on [::1]:53: read udp [::1]:50996->[::1]:53: read: connection refused
2019/10/28 02:02:31 [DVR] Starting job 1572228000-27 Mr. Robot on ch=[6052]
2019/10/28 02:02:31 [DVR] Waiting 1h27m28.995437903s until next job 1572233400-12 CBS 11 News at 10PM
2019/10/28 02:02:31 [ERR] Failed to start stream on channel 6052 via TVE-Dish: TVE: Post https://sp.auth.adobe.com/adobe-services/authorize: dial tcp: lookup sp.auth.adobe.com on [::1]:53: read udp [::1]:59582->[::1]:53: read: connection refused
2019/10/28 02:02:31 [DVR] Error running job 1572228000-27 Mr. Robot: could not start stream on channels=[6052]: TVE: Post https://sp.auth.adobe.com/adobe-services/authorize: dial tcp: lookup sp.auth.adobe.com on [::1]:53: read udp [::1]:59582->[::1]:53: read: connection refused
2019/10/28 02:03:01 [DVR] Starting job 1572228000-27 Mr. Robot on ch=[6052]
2019/10/28 02:03:01 [DVR] Waiting 1h26m58.945428069s until next job 1572233400-12 CBS 11 News at 10PM
2019/10/28 02:03:01 [ERR] Failed to start stream on channel 6052 via TVE-Dish: TVE: Post https://sp.auth.adobe.com/adobe-services/authorize: dial tcp: lookup sp.auth.adobe.com on [::1]:53: read udp [::1]:40638->[::1]:53: read: connection refused
2019/10/28 02:03:01 [DVR] Error running job 1572228000-27 Mr. Robot: could not start stream on channels=[6052]: TVE: Post https://sp.auth.adobe.com/adobe-services/authorize: dial tcp: lookup sp.auth.adobe.com on [::1]:53: read udp [::1]:40638->[::1]:53: read: connection refused
2019/10/28 02:03:31 [DVR] Starting job 1572228000-27 Mr. Robot on ch=[6052]
2019/10/28 02:03:31 [DVR] Waiting 1h26m28.870549011s until next job 1572233400-12 CBS 11 News at 10PM
2019/10/28 02:03:31 [ERR] Failed to start stream on channel 6052 via TVE-Dish: TVE: Post https://sp.auth.adobe.com/adobe-services/authorize: dial tcp: lookup sp.auth.adobe.com on [::1]:53: read udp [::1]:48485->[::1]:53: read: connection refused
2019/10/28 02:03:31 [DVR] Error running job 1572228000-27 Mr. Robot: could not start stream on channels=[6052]: TVE: Post https://sp.auth.adobe.com/adobe-services/authorize: dial tcp: lookup sp.auth.adobe.com on [::1]:53: read udp [::1]:48485->[::1]:53: read: connection refused
2019/10/28 02:04:01 [DVR] Starting job 1572228000-27 Mr. Robot on ch=[6052]
2019/10/28 02:04:01 [DVR] Waiting 1h25m58.808324053s until next job 1572233400-12 CBS 11 News at 10PM
2019/10/28 02:04:01 [ERR] Failed to start stream on channel 6052 via TVE-Dish: TVE: Post https://sp.auth.adobe.com/adobe-services/authorize: dial tcp: lookup sp.auth.adobe.com on [::1]:53: read udp [::1]:60528->[::1]:53: read: connection refused
2019/10/28 02:04:01 [DVR] Error running job 1572228000-27 Mr. Robot: could not start stream on channels=[6052]: TVE: Post https://sp.auth.adobe.com/adobe-services/authorize: dial tcp: lookup sp.auth.adobe.com on [::1]:53: read udp [::1]:60528->[::1]:53: read: connection refused
2019/10/28 02:04:31 [DVR] Starting job 1572228000-27 Mr. Robot on ch=[6052]
2019/10/28 02:04:31 [DVR] Waiting 1h25m28.759707195s until next job 1572233400-12 CBS 11 News at 10PM
2019/10/28 02:04:31 [ERR] Failed to start stream on channel 6052 via TVE-Dish: TVE: Post https://sp.auth.adobe.com/adobe-services/authorize: dial tcp: lookup sp.auth.adobe.com on [::1]:53: read udp [::1]:42911->[::1]:53: read: connection refused
2019/10/28 02:04:31 [DVR] Error running job 1572228000-27 Mr. Robot: could not start stream on channels=[6052]: TVE: Post https://sp.auth.adobe.com/adobe-services/authorize: dial tcp: lookup sp.auth.adobe.com on [::1]:53: read udp [::1]:42911->[::1]:53: read: connection refused
2019/10/28 02:05:01 [DVR] Starting job 1572228000-27 Mr. Robot on ch=[6052]
2019/10/28 02:05:01 [DVR] Waiting 1h24m58.698874754s until next job 1572233400-12 CBS 11 News at 10PM
2019/10/28 02:05:01 [ERR] Failed to start stream on channel 6052 via TVE-Dish: TVE: Post https://sp.auth.adobe.com/adobe-services/authorize: dial tcp: lookup sp.auth.adobe.com on [::1]:53: read udp [::1]:59087->[::1]:53: read: connection refused
2019/10/28 02:05:01 [DVR] Error running job 1572228000-27 Mr. Robot: could not start stream on channels=[6052]: TVE: Post https://sp.auth.adobe.com/adobe-services/authorize: dial tcp: lookup sp.auth.adobe.com on [::1]:53: read udp [::1]:59087->[::1]:53: read: connection refused
2019/10/28 02:05:31 [DVR] Starting job 1572228000-27 Mr. Robot on ch=[6052]
2019/10/28 02:05:31 [DVR] Waiting 1h24m28.648145671s until next job 1572233400-12 CBS 11 News at 10PM
2019/10/28 02:05:31 [ERR] Failed to start stream on channel 6052 via TVE-Dish: TVE: Post https://sp.auth.adobe.com/adobe-services/authorize: dial tcp: lookup sp.auth.adobe.com on [::1]:53: read udp [::1]:40913->[::1]:53: read: connection refused
2019/10/28 02:05:31 [DVR] Error running job 1572228000-27 Mr. Robot: could not start stream on channels=[6052]: TVE: Post https://sp.auth.adobe.com/adobe-services/authorize: dial tcp: lookup sp.auth.adobe.com on [::1]:53: read udp [::1]:40913->[::1]:53: read: connection refused
2019/10/28 02:06:01 [DVR] Skipping job because program already started 1572228000-27 Mr. Robot'
Restarting the server seems to have fixed whatever the issue is, but I'd like to avoid having this happen again in the future, if it's something glitchy on my end. I am running the TVE docker build, so I know it's a bit behind the "regular" release. Any clue what happened?
It sucks that this happened to literally the only show I record for myself, but for the sake of my sanity, it's better than happening to one of my wife's recordings, haha. Cutting the cord was a hard sell and she's finally pretty much on board now.
Looks like a DNS issue in your container. Your DNS server is set to [::1]:53 which is ipv6 localhost and it was not responding to DNS queries.
Thanks for the info, Aman! I'll have to do some more research on my end and figure out the weirdness known as Docker networks, haha. Or maybe I'll wait until something like this happens again on one of my wife's shows and I can use that to justify getting a NAS. :grin:
How do you fix this kind of dns issue?
I am getting the same thing when tuning live channels
Can your network settings under DNS
