Lost TVE for NBC & CBS on Fubo
A few days ago NBC & CBS disappeared from the TVE line using Fubo. The next day NBC was back but CBS is still missing.
CBS is still available on the Fubo app, and I can access the live feed using a browser and my Fubo credentials.
CBS does not even appear in the lineup. I have not ever been able to access ABC but it appears in the lineup noting that my local station does not support TVE.
If something changed with the TVE support from this station why is that not noted in the lineup?
Try unchecking and rechecking the experimental option for local channels?
I did as requested but CBS is still missing.
However, previous it showed ABC and a number of others as unavailable for TVE, but now they are all available.
We're on the fringe of that CBS station's coverage. Is it possible that the results of the geolocation services is not accurate? Since the browser prompted for approval of a geo request, it suggest that the location of the browser is being used and not the location of the server. Is that correct?
Can confirm I have also lost CBS from Fubo. When I tried unchecking and rechecking the local channels option I lost NBC as well.
Tried YouTubeTV as a test and all local channels, including CBS were accessed successfully.
So these local channels still support TVE, I can access them using the Fubo app, I can access their live stream using Fubo credentials, so the only time it fails is when you combine Fubo and ChannelsDVR.
Anything we can do to investigate further?
Any update on this?
I just rescanned channels and checked the log and found the entry below. It is clearly not correct because I am able to access CBS' stream with a browser using Fubo credentials.
2023/02/13 11:10:22.167024 [TVE] action=cbs_station err=CBS stream is not available via your TV provider
