Having issues with only UHF OTA channels - transcoder takes a long time to start and then usually frame rates are to low to be watchable. Many times it will never start - just sit and spin.
Have zero issues with any non-uhf OTA channels or any channels from streaming sources.
Have zero issues with the same UHF OTA channels watching directly on TV.
Any ideas - below is part of log from this morning.
2019/11/02 10:06:39 [TNR] Opened connection to 1044F128 for ch10.1 KTTCNBC
2019/11/02 10:06:40 [HLS] Starting transcoder for channel 10.1 from 192.168.0.115 (encoder=h264_mf, resolution=1080, deinterlacer=linear, bitrate=6000)
[mpegts @ 0000000000cec180] Dropped corrupted packet (stream = 0)
Last message repeated 1 times
[mpegts @ 0000000000cec180] Dropped corrupted packet (stream = 1)
[mpegts @ 0000000000cec180] Dropped corrupted packet (stream = 2)
Last message repeated 2 times
Last message repeated 3 times
Error while decoding stream #0:1: Error number -16976906 occurred
Error while decoding stream #0:2: Invalid data found when processing input
Error while decoding stream #0:2: Error number -16976906 occurred
[h264_mf @ 0000000000d09580] stream format change
Last message repeated 4 times
[mpeg2video @ 0000000000cf4140] Warning MVs not available
pipe:: corrupt decoded frame in stream 0
Last message repeated 5 times
2019/11/02 10:06:57 [HLS] Stopping transcoder session ch10.1-dANY-ip192.168.0.115 @ 15.337966s
2019/11/02 10:06:57 [TNR] Closed connection to 1044F128 for ch10.1 KTTCNBC
2019/11/02 10:08:19 [TNR] Opened connection to 1044F128 for ch10.3 HandI
2019/11/02 10:08:19 [HLS] Starting transcoder for channel 10.3 from 192.168.0.115 (encoder=h264_mf, resolution=1080, deinterlacer=linear, bitrate=6000)
[mpegts @ 00000000024ec180] Dropped corrupted packet (stream = 0)
[mpegts @ 00000000024ec180] Dropped corrupted packet (stream = 1)
[h264_mf @ 00000000028939c0] stream format change
[ac3 @ 00000000024f3240] new coupling coordinates must be present in block 0
[ac3 @ 00000000024f3240] error decoding the audio block
pipe:: corrupt decoded frame in stream 1
[mpeg2video @ 00000000024f2dc0] ac-tex damaged at 26 26
[mpeg2video @ 00000000024f2dc0] Warning MVs not available
[mpeg2video @ 00000000024f2dc0] end mismatch left=75 40000 at 0 30
[mpeg2video @ 00000000024f2dc0] ignoring pic cod ext after 0
Last message repeated 8 times
[mpeg2video @ 00000000024f2dc0] 00 motion_type at 32 0
[mpeg2video @ 00000000024f2dc0] 00 motion_type at 29 21
Last message repeated 7 times
[ac3 @ 00000000024f3240] invalid coupling range (11 >= 10)
2019/11/02 10:08:48 [HLS] Stopping transcoder session ch10.3-dANY-ip192.168.0.115 @ 26.660444s
2019/11/02 10:08:48 [TNR] Closed connection to 1044F128 for ch10.3 HandI
