All my M3u custom channels disappeared in my channels collections. They are there in “all” list. However seems the only way to get them back in to collections is to add one by one again.
Did their channel numbers change? Or their channel IDs?
Custom Channels from IPTV sources can be very unstable and change a lot, this is one of the problem with using untrusted sources.
Yeah, they are unstable, I did however check and channels #’s and ID’s are the same. If I go into the web UI they are all there in the all sources guide, just been eliminated in custom collections. I can add them back in but it is tedious. Any thoughts?
Submit diagnostics, and we'll look at the IDs, but Channel Collections are recorded by Channel ID, if that changes, then the record of them being in the Channel Collection is gone.
OK, I already added most of them back except movie collection. I’ll send diagnostics. Thanks
Diagnostics submitted from web UI
