Was wondering if the devs or anyone else would have any insight into my “issue”.
I use a combination of ChannelsDVR and Emby/plex, but all my TV runs through ChannelsDVR first.
When using Emby on Apple TVs I prefer to use the Native player - but for live tv it prefers HLS.
So if I use ?format=hls&codec=copy, my HDHR channels will be in HLS format and also be deinterlaced by channels amazing transcoder/remux.
The issue I’m having is if Emby is used for quick channel changes, the channels transcoder holds onto streams for atleast 10 seconds after terminating while using an external client. (From my memory this is not the case with ChannelsDVR clients)
Is there a way I can change this? Is this by design or is this an unavoidable consequence of using another client.
I know that direct playing from the CDVR server will terminate immediately, but really wanted to have HLS, but also mainly the efficient deinterlacing.
Thanks
