M3U - Tuner Sharing
So I’m using channels as the backend to feed channels to my Emby server.
How do I get tuner sharing working while using the m3u link from channels ?
If you're requesting the streams from the server directly, it is already doing tuner sharing.
Tuner sharing is only in relation to Channels client apps and HDHR tuners. If you are not using the Channels app, then tuner sharing doesn't matter.
