Watching Magnolia channel and the feed keeps freezing. I hit back and go back to guide and navigate back to channel immediately starts playing again.
Submitting diagnostics (0d8b80c3-11e2-4677-bb6b-2b9d6ffa1829).
Any suggestions?
Any suggestions?
Don't support Joanna Gaines?
/s
Is this only with Magnolia, or all Discovery/WBD channels? What is the source? Any logs?
Source is Fubo Project. Logs don't show any errors, I'm assuming the diagnostic log I submitted from the client may have more info for the Devs to see. I'll have to check the other channels.
Do you see timeouts or other errors in your log. If it's timeouts, there is probably internet congestion between you are the source. I record a few shows from Magnolia via TVE and they work fine. Also check your LAN as it could be a combination of problems.
