Magnolia Channel on Dish not working for me
Starting getting this error for Magnolia Channel (DIY) on Dish TVE. Just started today. Other channels from Discover+ work fine.
registration: GET: https://us1-prod-direct.destinationamerica.com/v1/gauth/authorize?brand_id=5af44aba6b66d153ea57bd1c&no_redirect=1&partner_id=5a9052b46b66d103ef3b2984&redirect_url=https%3A%2F%2Fauth.destinationamerica.com%2Fgauth-sync: 400 Bad Request: "{"response":"failure","code":4000,"status":400,"locale":"en-US","title":"Bad Request","message":"An error occurred. Please contact support"}\n"
Thanks for reporting this. Please update to the latest pre-release and let us know if it resolves the issue.
I had a couple of failed recordings from earlier today on the same channel with the same error. Updated to latest pre-release. I will set up some recordings tonight to check out the fix too.
[Edit] Recordings work fine. Thanks for the fix.
Yes this has resolved it! Thanks!
