I seem to be getting duplicate Movies ... but when I go to DVR manage, I cannot sort by title to check for duplicates .... can this be added ?
This is from my IFC Collection just a small sample ...
I agree it would be nice to sort alphabetically in DVR > Manage > Movies
Do you see the duplicates in Library > Movies when sorted alphabetically?
yes I see them ...I wonder if TVE and Regular Cable guide can be causing the movie DUPS.
You could investigate them like you did for your FBI dups.
Click View Details, then the File ID number on the dups and see what the JobID is.
"JobID":"1658620680-100"
1658620680 is the unix epoch time of recording
-100 means it was scheduled by pass (rule) #100
"JobID":"1671390000-ch120"
1671390000 is the unix epoch time of recording
-ch120 means it was manually scheduled from channel 120
Another thing is that in manage DVR you cannot even filter by recorded movies ... so it is not easy to check for dups.
But it appears they got more pressing matters like fixing advance pass.
Ok I see it now.
That's from
Of course as you mentioned no alphabetical sort there
Library > Movies
First it's FBI episodes, now Movies.
Wonder what is going on?
Yeah but if you try to filter to just recordings or imports it will show all regardless. Those filters don't do anything on the back end
OK, but it works on my DVR.
Ahh OK. @maddox My bug only happens if you set the filter to Unverified AND select recordings or Imports. When you do that it just displays all items and ignores other filters.
Right, that shows both Imported and recorded. Verified or unverified.
