Manual adding of commercial detection
I have set up a series pass for children's shows. Unfortunately, the 5-minute long show is usually embedded in a 15 segment where there are children's presenters on screen. The effect of this is that the presenter bit is (rightly) not detected as a commercial and therefore cannot be skipped.
Unfortunately, this also means that as no commercials have been detected there is no option to "Re-edit commercials". Is this the intended behaviour? If so, is there a workaround that anyone can suggest? I want to be able to skip the presenter parts of the segment.
P.S. Detect commercials is ticked.
