Manual change channel numbers from web gui
Hi,
I would like to request a new feature for the DVR Server.
I would like to be able to manualy modify the channel number from the web interface.
In the following example, I would like to delete 9000 and enter 1
Thanks
Since you are using a M3U playlist to define your channels, you can specify the channel numbers in the playlist itself. Channels recognizes both the channel-number and tvg-chno tags for defining channel numbers.
@tmm1, does Channels' M3U parser also support Tvheadend's tvh-chnum tag, or just the other two tags? (I can't remember if I asked this previously.)
I've added tvh-chnum in the next build.
