If you mean, "How do you reverse the process?", the answer is use the DELETE method at the same endpoint.
curl -XDELETE http://dvr:8089/comskip/ignore/channel/840
Thank you,
Apparently curl options are different on Windows yet now that I learned curl it's easy for me to translate. My test confirmed operation and I've the rest of my premium channels.
Have a happy new year!
Morris
You can use curl.exe on windows which is included and works the same way.
Without the exe it uses powershell's IWR (Invoke-WebRequest)
Thank you,
The back story on why this is would be interesting.
Have a Happy New Year,
Morris
If you're using OliveTin for Channels, it has an action button to do that as well as list the channels you have disabled it on. OliveTin for Channels: An Interface for Misc Channels DVR Scripts & Tricks
