Manual Recording with no ComSkip
With the latest Channels DVR Beta installed, my ComSkip is finally working as it is supposed to do. I have a 3 hour manual recording every day on Fox Business. It needs to be manual so I can tinker with the start and end times. After the recording, Channels does a ComSkip run, which is my default.
However, ComSkip does not work on Fox Business TVE, so my CPU is grinding away on a 3 hour recording with no useful results.
I would like to be able to specify that this particular manual recording should not be ComSkipped as part of the initial manual recording request.
Give the recording request a seriesID on the JSON payload, then after one recording go to the series' page in the DVR to turn off commercial detection for that series.
Great, I'll give it a try.
One option I'm considering is a list of channel numbers for which comskip will be skipped. This has been requested by @Robinlmp and other UK users in the past. Would that work for your usecase?
The option for pre-selecting channels (UK) to not comskip would be good... yes please.
Yes, that would work for me. The only reason I don't ComSkip is because it doesn't work at all on some channels, and is not needed on PBS where there are no commercials.
I didn't get a chance to add a UI for this today, but the API backend is there in the next prerelease.
For example, if channel 1009 is PBS:
curl -XPUT http://x.x.x.x:8089/comskip/ignore/channel/1009
Great! I just added 5 channels. I'll see what happens in a few hours.
Ken
I added Channel ID's and it did not seem to work. Then I added real channel numbers and it now seems to work.
Is there a way to remove the wrong numbers I put in?
Thanks much for this WONDERFUL feature.
Ken
Did you try
curl -XDELETE http://x:8089/comskip/ignore/channel/1009
I never used -XDELETE before, so I gave it a try. It reports success no matter what I send, so there is no way to know if it actually did anything.
Ken
What about GET /comskip/ignore/channel? Or any path further up the chain?
I haven't used that new option yet, but check settings, they should be in there.
http://x:8089/settings
I just verified that's where they are
Yet another problem solved. Yet another thing learned.
You guys are GREAT!
Awesome. I was just thinking about this the other day. Hoping for the UI portion soon :slight_smile:
Any updates on adding a UI for this? I would like to disable ComSkip for all my ATSC 3.0 channels.
As referenced further up in the thread, you can do this for each ATSC3 channel:
But no, there is not a UI for this yet.
I just tried after upgrading to the fastest beta by using:
http://dvr:8089/comskip/ignore/channel/840
and got:
404 Not Found
You made sure to use the PUT method, yes? A GET request (the default if you don't specify one) would indeed return 404.
having never used curl, this took some reading and then I tried:
curl -method put http://dvr:8089/comskip/ignore/channel/840
This appears to be valid
what is the opposite of "ignore"?
Thank you. I'm going to kick off a recording to check the for the desired effect before doing lots of channels
