I know it's been discussed before that you can somehow manually set a "manual" recording even though it isn't supported for chunks of time. I've read the thread in the past, but still can't get it to work. For example, if I wanted to record TVE CBSN New York every day from 7am until 9am how would I do that manually?
Manual recordings are per recording.
There is no way to do that in a Series Pass.
That's something on my wish list to be able to set a manual, repeating recording.
Like TiVo (my former and still using DVR) does.
Create manual recordings for each one, everyday, 7 per week.
You could create one per day for the rest of the year, 365 manual recordings.
It would work, but labor intensive.
How though, that is my question. I’ve tried searching the threads here but can’t find the one that outlined how to trick the system into doing it?
Here's the thread:
There are several different methods presented.
