Is there a way to mark my favorite channels using the Firestick Remote? Right now it seems as though the only want to mark favorite channels is the go into settings and then select the favorites from Manage Sources. It works, but it's really awkward!
You can do it via On Now by click-and-hold on a channel
Thank you... I did also notice that there seems to be a limit to the "On NOW" channels. How many will it display? I would be nice to implement something in the channel guide since not all of the channels show up on "on now."
While you're here, some movies show up as TV shows when I record them. Is there some way to specify that when I record it? Currently I have to move the file manually to an imported movies sub directory and then import it. When I do it loses all the commercial detection and I have to re-detect them.
There is a filter at the top of On Now. If you set it to all then all your channels would appear.
No, it has to be specified in the XMLTV file that it's a movie.
Check our Channel Collections to curate your own sets of channels.
