It looks like Marquee finally allows Xfinity login. This had been "coming soon" until just this week. Should this work through TVE? I don't see the channel but I wasn't sure if an update needs to be pushed out to enable it.
Try the latest pre-release
I just updated to 2020.09.04.1649 and clicked "Rescan New Channels". I believe Marquee Sports Network should be channel 6156 (from what I saw in another thread) but I'm still not seeing it. Am I missing a step?
Click Edit at the top right, find the channel and click rescan next to it
That did it! Thanks for your help!
I clicked the gear next to it and clicked Rescan and then it worked. I'm assuming you have access to Marquee in your cable package? I don't think it's in the lower packages.
In case anyone isn’t sure how to update to the prerelease update, hold the update button down for 3 seconds to start downloading the latest prerelease. I needed to do that in order for me to be able to complete the steps above to edit and enable Marquee network.
