Hi, what’s the max number amount of channels the TV guide loads?
Can it load over 2000 channels?
Or is there anywhere where I can read about the info.
If you’re asking about Custom Channels, it can only load 500 channels from an m3u source.
Is that per source m3u or across all m3u sources? Thanks!
Per.
But if you plan on putting 2000 channels in, don’t be surprised if it’s not a fun time.
