I'm able to install CDVR as a user agent, but have a couple issues with that.
Trying to figure out how to make it work as a system service writing to a shared Synology SMB folder.
I'm curious how you ended up architecting your project and whether there were any gotchas.
I'm considering a similar migration of my Docker/Portainer setup from a Synology to the Mac mini that already runs my CDVR on bare metal.
I currently run ADBTuner in the Portainer but am trying to add OliveTin. I've attempted to configure OliveTin on the Synology but run into issues configuring it: the mini doesn't really want to let OliveTin access the DVR and CHANNELS_DVR shares and I get 500 errors when deploying OliveTin.
Rather than fight the mini's lack of sharing...I'm thinking I should move my Docker/Portainer setup to the mini so everything is within a single user instance.
Is that how you have it setup? Is it working well for you?
Thanks for any insight you can provide....
I gave up moving my seven Channels DVR servers and supporting docker containers to my Mac Mini M4. They're still running on my Synology NAS.
There is an old saying. "Don't fix what's not broken."
Oh! That's not the answer I was expecting. lol.
Would you recommend against running Docker on the Mac?
I don't really want to change my working setup but seems like OliveTin needs easy access to the DVR shares and (best I can tell) the Mac doesn't want to be that kind of server.
My options are:
- Move docker/portainer to Mac
- Move DVR to Synology
- Move everything to a windows box with the right specs
No.
It just wouldn't work the way I wanted it to. I was expecting everything to run on the Mac as a background service and not have to set my Mac to auto login my user when it booted. I didn't want to spend any more time than I did trying that.
I was able to install OliveTin EZ-Start yesterday, used that to install Portainer and the full version of OliveTin which found the DVR folders on the mini just like I hoped.
Have now installed ADBTuner and FruitDeepLinks and am puzzling through that setup.
OliveTin really makes it easy.
