After using Channels Live TV for a couple of weeks now, I've noticed a few things:
If a channel is a bit weak and starts to pixellate a bit, the whole stream just pauses briefly. This is a bit jarring to watch. To work around this I pause for 5 seconds or so and then any pixellation just goes by without a jarring pause. Could you possibly consider an option to auto-buffer 5 seconds upon a channel change so that users can avoid this?
I just purchased a couple of new tuners to work around some multipath interference as well as some issues with using HDHR3 units with Channels Live TV. I can't seem to find any way to get rid of the references to my old tuners in the app. Am I missing something?
I'm assuming that guide data comes from over-the-air EPG information. For some reason, CFPL-HD (London, Ontario) never gives any guide data when my old software always got it. Not sure what can be done for that.
Other than those few minor things we're really enjoying using the app. Thank you so much for your work and continuing efforts!
