Missed recordings - Error code 503
DVR was working great earlier this evening then I noticed it wasnt recording a couple shows. I checked the log and had many errors similar to this: “Failed to start stream on channel 11.1 via 1046A13B: got http response code 503”
I think that’s a no tuner available error, did you have other recordings (live streams) going at the same time?
Yes 503 means no tuners available. On OTA models it can also mean the channel’s signal was not strong enough.
Thanks for the responses. Kind of strange though. I have two HDHomerun Connects and was watching a recording while the two shows failed to record on channels that consistently report 80-90% signal strength according to the HDhomerun software. Hopefully one of my tuners isnt going bad.
If you email the log to [email protected] I can take a look.
Any other software running that might be using the tuners?
