Missing a lot of guide data
So I switched to a Yagi antenna as the reception on my previous antenna was laughable.
But now even though the channels are coming in clear, I am missing guide data
How do I solve this?
On the DVR web UI click the circle refresh icon under your HDHR.
Wow. Thanks.
I am considering changing my antenna. Which yogi did you get?
RCA Yagi.
Thanks. Any particular model?
I had the same problem but doing what you suggested didn't fixed. Any other idea? thank you
Are you using a HDHomeRun?
Yes. Actually I just restarted everything again and it is working. Thank you !
