I will have a look at the cpu and ram load while keeping channels busy.
I have been using dvblink for many years with different service providers, some 8-10 years ago I had iptv direct from my provider and with dvblink I had 8 virtual tuners available. At that time I could record 8 streams simultaneously and actually I am still using the same NAS as then. Only difference is that back then it was through ISCSI and now it is SMB but I don’t think that makes much of a difference
Recording to a network mount is not recommended
What is your recommendation local SSD or ???
Local HDD over USB3
I am trying to get some EPG onto this channel
I tried to use the one below
https://github.com/epgshare01/share01/blob/master/epg_ripper_ALL_SOURCES1.xml.gz
It has News12Plus Bronx, but it just breaks up the channel into 30m segments instead of what is listed on the stream's website.
epg.best only has the normal (non plus) channels.
Anyone have any further ideas I can explore?
Have you tried mapping it to N12PCT
"type": "Cable Only",
"name": "News 12+ CT",
"callSign": "N12PCT",
"stationId": "112736",
"bcastLangs": [
"en"
"preferredImage": {
"uri": "https://tmsimg.fancybits.co/assets/s18690_ll_h15_ab.png?w=360&h=270",
"height": "270",
"width": "360",
"primary": "true",
"category": "Logo",
"text": "",
"tier": ""
"videoQuality": {
"signalType": "Digital",
"videoType": "HDTV",
"truResolution": "HD 1080i"
Thanks, I don't know why I never got it to show up before, but that worked perfectly.
