I just noticed that my guide data is missing for Ziply Fiber on my Prime. I still have data for my Quatro OTA. I tried to redownload all guide data, but it’s still not showing in either the app or the web guide. What should I check?
I just noticed this in the log:
2021/01/22 23:53:38.436031 http: TLS handshake error from [fe80::1875:c061:823f:b1c1%Ethernet]:53130: EOF
2021/01/22 23:53:38.514857 http: TLS handshake error from [fe80::1875:c061:823f:b1c1%Ethernet]:53131: EOF
2021/01/22 23:54:04.468390 [ERR] No stations available in lineup USA-WA67390-X during guide data download
I think you need to reset the provider and pick Ziply again.
I removed the provider from the Prime and re-added Ziply (it probably still had the old Frontier provider). I also deleted and redownloaded the guide database. I still don’t have guide data for this tuner in Channels. I do see the guide data in the HDHomerun app, if that means anything.
I see some of these log entries now:
2021/01/23 10:33:53.655499 [DVR] Fetching guide data for 51 stations in USA-WA71730-DEFAULT @ 2021-02-08 4:00AM
2021/01/23 10:33:54.688499 [DVR] indexed 317 airings (51 channels) [0s fetch, 0s index]
2021/01/23 10:33:55.422573 [DVR] indexed 5 movies (5 channels) [0s fetch, 0s index]
How many channels listed under your HDHR?
Try clicking gear icon and select Sync Mapping
That did the trick, thanks!!!
