Missing guide data from Gracenote
Relatively new OTA channel in Atlanta, GA is missing from the Gracenote lineup (USA-OTA30064), WUEO-LD channel 49. 49.1 is MeTV and 49.5 is Accuweather. The other subs are infomercials. Data is present for this channel in the HDHomerun listing, but not Gracenote listings used by DVR. Is there a way for you to contact Gracenote to get this channel added to their lineup? Thanks.
I submitted these to Gracenote to fix
Necrobump
A new OTA has been added to our local lineup, channel 40.5 Defy
It has been up for a couple weeks now but guide data hasn't showed up yet. How do I go about investigating this?
Is it listed on zap2it.com for your zipcode?
If not you could try emailing them (good luck) or asking SiliconDust about it https://forum.silicondust.com/forum/viewforum.php?f=127
No sir, it doesn't. I found it on another site with no guide info also. I suppose they are taking their time then.
Defy is also new to my area via OTA, but it is weak signal.
Locast has yet to add it.
I emailed them and got generic response that my request was forwarded to their engineering department.
It should be appearing soon in the guide. Just showed up on zap2it for my area.
For those unsure if they have it you can see where it's being broadcast from their website https://www.defytvnet.com/findus/
