Missing Local Fox Channel Guide Data
I am in the Atlanta TV market and I have seemed to have lost the guide data. In the guide only shows SIGN OFF for all time slots. I can search for some programming on fox and it shows up. Just not in the guide view. It seems my season passes are still picking up Fox programming as well. I can watch the fox channel just fine. I have tried the "re-download entire guide" feature and I still have the same problem.
Screenshot 2023-01-26 at 8.56.50 AM
Do you have information on it around 700pm. The FOX channel only shows primetime shows for the most of us. It just depends on who owns the station. The rest of the time it will be SIGN OFF.
The Atlanta Fox station is owned by Fox Corp so they should have a full guide, even outside of prime time.
Wow! Yeah it seems that primetime and sporting events are the only ones listed. I don't know when this changed, but very unfortunate that the local channel is not wanting to share that information.
Does it say sign off on fox.com/live?
What is the station callsign?
WAGA Fox 5 Atlanta
No it is ok on their website.
Channels Guide
Sniff Sniff thought I would try and see too. I am not that lucky.
WAGA fixed in prerelese.
Fantastic.
I just updated to pre-release: 2023.01.26.1704
Then re-downloaded guide data.
I'm seeing the same problem for KQPQ in the Seattle market. Using latest pre-release and downloaded the latest guide data but still see SIGN OFF in the guide data. Tuning to the channel (6002) on a Channels client I can view the local KCPQ programming but the guide shows it at SIGN OFF.
This is how it is listed in the YouTubeTV source.
I can watch the Fox local feed over at fox.com/live just fine.
Any ideas how to get the proper guide date to show up?
