Missing "Manage Passes"
On the latest Apple TV Channels App, there is no way to manage "Passes" anymore. On the Fire TV there is a manage passes button that allows priorities to be set, etc. No such option on the IOS App. Is this being addressed?
You are still able to add and delete passes as before. The only thing that was removed was the ability to re-order passes.
There’s no plan to add this back, due to technical difficulties. Please use the web admin if you need to change the priority order of your passes
If you are having to manage priorities this much because of missing recordings, and are generally invested in Channels as a TV platform, I would highly suggest purchasing an additional tuner so that you don’t miss recordings at all.
Channels is very adjustable in that there’s really no reason you have to miss recordings due to tuner or storage limitations.
