I have an issue I can not fix. If I download and run the Channels app all 36 local channels play fine and all guide data is populated for them.
If I install the DVR server, and complete/finish setup all 36 local channels are still found however the very first 3.1 WBTV CBS channel out of Charlotte, NC will display blank no data in the guide and not allow recording of that channel. All other channels display and record perfectly fine. Even the sub channels 3.2 and 3.3 show up in the guide data and allow recording, but not the main 3.1 WBTV CBS channel?
However if I go uninstall the Channels DVR Server, then use the regular Channels app it displays 3.1 WBTV CBS channel in guide with all data and plays it fine.
Update: Looks like I refreshed the guide data a few times and about 10-15 minutes the main 3.1 CBS feed data has appeared.
