Is it possible to mix Provider data and XML sourced guide data together?
For example, I send HDHomeRun runners to xTeve.
In xTeve I have added some other sources m3 i channels.
In Channels, I pull the combined playlist from xTeve as a new source tuner - so far so good.
I have tried Guide2Go (which sources guide data from Schedules Direct on a paid subscription) however the tv show artwork is randomly pulling through, roughly only 10% of the time. I have tried using the Channels Provider data which works 100% of the time for artwork however, as I have channels that are not from HdHomeRun, the Provider guide tries to match those channels and it is an incorrect match.
How can I set some channels to Provider and others to XML?
You can create two custom channels sources
@tmm1 thank you. I didn’t think of that. Have added a new source and just deselecting channels so no duplication between both sources and each source independently supplies a different guide
