MLB.TV for Channels
Can you screenshot that?
AFAIK Web station is used for hosting web sites. I haven't seen that on my NAS.
It is. I’m not really sure why I had that installed, but I uninstalled it. So does MLB show up under sources now? If so, I’m not seeing it.
If you are speaking of a tuning "source" in CDVR no. It needs to be added. Lets see if you can access the webpage for MLB for channels.
If I go here: http://192.168.1.200:8088/ it pulls up my MLB for channels web page. On that page are the 2 links you need for setting up your source.
192.168.1.200 is my Synology NAS 8088 is the port I used for it.
Use your Synology IP and your port number and see what you get.
Yeah I’m just getting a connection timeout. I’ll just screw around with it for awhile and see if I can get it. Thanks for the help.
You're welcome. Happy to help. A couple of things you can check:
You can open Docker on the NAS from the package center.
Verify the container you created is there and running.
If you want to check your setup stop the container and click edit.
interesting development as the bean counters negotiate:
I hope Bally goes under. Worst thing to happen atleast in my area. Bally Sports Southwest. The app is terrible. The audio difference from shows on my HDHomeRun and TVE is a world of difference. 14 is the volume set for regular shows and Bally is like like 40-45. The broadcast also looks like garbage compared to ESPN & ABC broadcasts.
Hi there,
I have noticed SDP stream has changed. i can stream the Big inningj and so on.
Thanks
I'm getting this error when trying to tune to any of the MLB streams today.
2023/03/14 13:57:38.924818 [ERR] Failed to start stream for ch7010: M3U: Could not fetch playlist: 192.168.1.250:8080: get http://192.168.1.250:8080/playlist/PHI: 500 Internal Server Error
2023/03/14 13:57:38.972061 [HLS] Couldn't generate stream playlist for ch7010-dANY-ip192.168.1.100: M3U: Could not fetch playlist: 192.168.1.250:8080: get http://192.168.1.250:8080/playlist/PHI: 500 Internal Server Error
2023/03/14 13:57:38.972169 [HLS] Stopping transcoder session ch7010-dANY-ip192.168.1.100
Any ideas?
What team are you trying to play?
MLB has changed some streams.
I'm unsure of what has and what hasen't changed.
The video server is turned off when they update the ads to be inserted during the breaks.
On Channels we don't see the ads.
I tried several active games.
Preseason is hit and miss, some games will work some won't. @crackers8199 doesn't sign up for mlb until the season starts when the deals come out. So until then its kind of get what you get.
I get that, but I had no issues up until today, and now every single stream has the same error, so either something has changed across the board or I have a problem on my end.
Sometimes they all work for me and sometimes none work... I just usually go over to the mlb app when things start messing up
Hi there,
I was able to watch the angels game today. I've got MLB to get me through pre-season. the t-mobile promotion comes out here at end of March. When all the teams start using their respective streams, i think we will see more of them working.
If two teams are on the same field, they will have one team stream the game to save bandwidth.
I appreciate all the great work that has gone into providing the MLB stuff to fellow users.
Not really. Only one is televised because they don't want to incur the production costs of a preseason game if they don't have to.
Wow! Got any other wishes?
He also hopes the Pirates win the world series
All my streams are still returning the same error, and nobody else appears to be seeing that, so I'm going to go out on a limb and say that it's just me. Does anyone know what I can do to troubleshoot?
What you were told, wait until @crackers8199 gets a sub so he check.
Remember this for next year, because it happens every year.
