MLB.TV for Channels
I found that I am not getting an EPG list the MLB games schedule
What does your Custom Channels setup look like?
http://localhost:8080/epg.xml
Try removing LOCAL HOST and put in the IP of the server.
Thanks i do that
just a thank you to @crackers8199. it was a quick setup and integration into Channels.
and it works with Xteve for those devices that cant run Channels.
I made a website in which you can track your yahoo fantasy team, when they are bat, pitching etc…it is using mlb.tv for channels by either automatically changing the channel for you or you can manually do it by pressing the player. I’d love others to try it out who play fantasy baseball. It’s at https://fantasychanger.com
Yeah...there's a similar tool on baseball-reference and mlbserver too (MLB.TV GAMECHANGER). It is pretty useful for gamblers/fantasy players
Maybe it could be implemented in thus docker too?
Can someone try the St. Louis Cardinals feed and see if it is working for you? I’m getting tuner not available for them but all the other channels seem fine.
Working for me.
Thanks for checking @troyboyjbl i think I’m a victim of the m3u locking bug. I restarted channels server and it’s working now.
"Restarted Channels"??? How do you do this :sunglasses:
Olive tin can
OliveTin-for-Channels has an Action to restart or shutdown your Channels DVR. :slight_smile:
Wish it was built-in :star_struck:
it is, on the better operating system. :wink:
Synology?
MacOS
Curious as to why they would have a restart on MacOS and not Windows?
If I remember correctly, they are all Apple/linux developers first. Apple is their flagship platform.
