Can somebody walk me through how to install this on the Channels DVR server running on my Raspberry Pi 4? I am not a computer scientist like most of you on here. I followed the directions here:Channels โ Raspberry Pi for setting up my server and it works great. Just no idea how to add docker to it and install the MLB.TV script. thanks!
Doesn't MLB.tv already provide dvd through their app? I get people want to record it with channels but they give you a pretty cool interface.
Does MLB allow you to download the file to add to your library or just allow you to watch it on their site/through the app?
It's just a stream in their app/site. But when you fast forward it's a really good experience. Showing you the current score while fast forwarding. Doesn't let you download it I dont think.
Try using the IP Of the server instead of Localhost. And make sure 8080 is the correct port.
I did get the same error when using the ip of the LocalHost I am using 8080 port, wish there was a newly updated docker for MLB.
Why? This one works fine...
Try restarting the docker and see what happens.
Looks like Username/password are incorrect.
I was wondering if you could share the docker for MLB you are using please remove your email and password.... Thanks
P.S. I did log into MLB.com with user name and password I am using for Docker it works on the website
I use Unraid and set it up a totally different way but based it off this Yaml.
version: "2"
services:
channels-baseball-new:
image: matty8199/channels-baseball:latest
container_name: channels-baseball
environment:
- APP_URL='http://localhost:8181'
- LOG_LEVEL='warning'
- MLB_USERNAME=''
- MLB_PASSWORD=''
- MLB_BITRATE='5600'
- MLB_PLAYLIST_FIRST_CHANNEL='3100'
- MLB_TEAM_ORDER='MLB,BOS,SDP,WAS,NYM,PIT,LAA,ATL,MIA,PHI,CHC,CIN,MIL,STL,ARI,COL,LAD,SFG,BAL,NYY,TBR,TOR,CWS,CLE,DET,KCR,MIN,HOU,OAK,SEA,TEX,MLB'
- MLB_TIMEZONE='America/Los_Angeles'
- MLB_SHOW_TV_FEEDS=true
- MLB_SHOW_RADIO_FEEDS=false
ports:
- 8181:8080
volumes:
- storage_app:/var/www/html/storage/app
- storage_logs:/var/www/html/storage/logs
volumes:
storage_app:
storage_logs:
Can you show your docker setup?
docker run -p 8080:8080 --name channels-baseball -v storage_app:/var/www/html/storage/app -v storage_gs:/var/www/html/storage/logs APP_URL='http://192.158.1.108:8282' MLB_USERNAME=
MLB_PASSWORD=โโ MLB_PLAYLIST_FIRST_CHANNEL=22000 MLB_TEAM_ORDER='MLB,NYM,SDP,PIT,LAA,ATL,MIA,PHI,WAS,CHC,CIN,MIL,STL,ARI,COL,LAD,SFG,BAL,BOS,NYY,TBR,TOR,CWS,CLE,DET,KCR,MIN,HOU,OAK,SEA,TEX' -e MLB_BITRATE='5600' -e -e MLB_BITRATE='5600'
-e MLB_TIMEZONE='America/Los_Angeles' \
-e MLB_SHOW_TV_FEEDS=true \
-e MLB_SHOW_RADIO_FEEDS=false \
These need a -e to set them as environment variable.
Can you do it line by line so it's not all bunched up together?
It should look like this.
docker run
-v storage_logs:/var/www/html/storage/logs
-e APP_URL='http://server.ip:8080'
-e MLB_USERNAME='xxx' -e MLB_PASSWORD='xxx'
-e MLB_PLAYLIST_FIRST_CHANNEL='777'
-e MLB_TEAM_ORDER='NYM,SDP,PIT,LAA,ATL,MIA,PHI,WAS,CHC,CIN,MIL,STL,ARI,COL,LAD,SFG,BAL,BOS,NYY,TBR,TOR,CWS,CLE,DET,KCR,MIN,HOU,OAK,SEA,TEX,MLB'
Thanks for your help I try that
ANy luck?
Yes TY I am back up thanks again
