[mpegts @ 0x7ff110008000] Dropped corrupted packet (stream = 1)
[mpeg2video @ 0x7ff110046c00] ac-tex damaged at 118 12
[mpeg2video @ 0x7ff110046c00] Warning MVs not available
Playback of live stream doesn’t work on Mac. The circle spins. HDHomeRun Connect appears normal.
More:
[mpegts @ 0x7fe92d801200] Dropped corrupted packet (stream = 0)
[mpegts @ 0x7fe92d801200] Dropped corrupted packet (stream = 1)
[mpeg2video @ 0x7fe92e04c600] ignoring pic cod ext after 0
[mpeg2video @ 0x7fe92e04c600] ignoring extra picture following a frame-picture
Last message repeated 1 times
[mpeg2video @ 0x7fe92e04c600] Missing picture start code, guessing missing values
[ac3 @ 0x7fe92e03dc00] expacc 125 is out-of-range
[ac3 @ 0x7fe92e03dc00] error decoding the audio block
[ac3 @ 0x7fe92e03dc00] frame sync error
Error while decoding stream #0:1: Invalid data found when processing input
2017/09/29 21:16:05 [HLS] Stopping transcoder session ANY-ch2.1 @ 5.271934s
2017/09/29 21:16:05 [TNR] Closed connection to 10487C51 for ch2.1
[mpeg2video @ 0x7fe92e04c600] ac-tex damaged at 27 36
[mpeg2video @ 0x7fe92e04c600] Warning MVs not available
2017/09/29 21:17:54 [SYS] Starting Channels DVR v2017.09.01.0513 (darwin-x86_64) in /Users/donmiller/channels-dvr/data
2017/09/29 21:17:55 [HDR] Found 1 devices
2017/09/29 21:17:56 [SYS] Started HTTP Server
2017/09/29 21:18:00 [DVR] Recording engine started in /Volumes/Media/ChannelsDVR
2017/09/29 21:18:00 [DVR] Waiting 41m59.398277s until next job 1506740400-24 Star Trek: Voyager
2017/09/29 21:18:00 soapRequest returned error: soapRequest error - StatusCode 500 for AddPortMapping()
2017/09/29 21:18:00 [NAT] Failed to map port using upnp: soapRequest error - StatusCode 500 for AddPortMapping()
2017/09/29 21:18:01 [SYS] Created database snapshot: backup-20170929.211800
2017/09/29 21:18:01 [SYS] Removing old backup backup-20170904.131325
2017/09/29 21:18:01 [SYS] Bonjour service registered with Dons-iMac.local
2017/09/29 21:18:10 [IDX] Pruned 0 expired airings from USA-OTA60525 in 772µs.
2017/09/29 21:18:13 [TNR] Opened connection to 10487C51 for ch2.1
2017/09/29 21:18:13 [HLS] Starting transcoder for channel 2.1 (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
2017/09/29 21:18:37 [HLS] Stopping transcoder session ANY-ch2.1 @ 22.489133s
2017/09/29 21:18:37 [TNR] Closed connection to 10487C51 for ch2.1
[mpegts @ 0x7f9f5680ec00] Dropped corrupted packet (stream = 1)
[mpeg2video @ 0x7f9f5684d600] ac-tex damaged at 30 26
[mpeg2video @ 0x7f9f5684d600] Warning MVs not available
More:
