Mounting a thumb drive to a Raspberry pi DVR
Does Channels DVR, on a Raspberry pi, support the mounting of a USB thumb drive?
Yes
Thanks for the quick answer. I'm brand new to Channels DVR but not RPi. I will be darned, however, if I can see the drive (via df or /proc/mounts.)
How might I see/access the thumb drive?
Try this:
  1. Log in (local or remote)
  2. Insert your thumb drive
  3. Check the output of dmesg | tail
That ought to give you a good start for why you aren't seeing the drive as expected.
(If you'd like something a little more interactive, you can also do journalctl -kb instead of the dmesg | tail. For more on this, check out journalctl(1).)
Ah ha! Thanks much!
I did not see that (SCSI) coming.
