Good quality flash memory cards last long time in my experience. I have had the same SD card used as internal storage in various Android phones and devices for many years, and have stash of old slower cards that still function fine. There are even professional diagnostics OS bootable usb sticks that use a MicroSD card as its flash memory. PCDoctor is one. That i have used for many years dozens a time each day for years. still works fine. that article is also a bit outdated. from 2017. flash memory has evolved and improved alot since then.
I also have 2 samsung SD cards in my 2 dash cams. they are 6yrs old. and have seen heavy constant read/writting, as with any dvr, and that extreme condition has not caused any less life of the cards. The Samsung chips the Pro models have a 10yr warranty even, so they build them to last.
On the other hand, i have tossed out hundreds of various brands of dead failed usb flash drives over the years. we used them as diag tool kits at my work, and they lasted about 4 months before they failed due to usage. moved over to the sd based ones, still work years later.
Anyway, about the pi, and trying to get the Channels image to boot for me, as i said, i have the most recent eeprom version, and it will not boot to a bootable usb. I have tried a few live linux distros, even the pi os image flashed to a usb stick. it just boots to no sd card found screen. is there a boot selection menu, like a F# key i need to press to get to that to select usb boot?? (did not mean to hijack this thread but seeing it pop up gave me the idea to try out channels on the pi as well as i did not know i supported usb stick boot)
(I am new to Pi and it seems it does not really work the same as other PCs i have used.)
