Movie Logos in Italian?
For the past several months, some of my Movie Logos, both on the Server GUI and the Client HERO screens are in Italian, rather than English. Did I accidentally change a setting?
When I try to edit the Logo to correct to English, there isn't any other option.
I've been having an issue with some obscure shows showing the "logos" for the wrong show with a similar name. There's a way to change it to the correct one, but I don't bother and have forgotten what it entails. But presumably you could find the English one. Just be thankful the picture is correct so you have some idea what it really is.
Thanks, I found that if I remove the logo, it replaces it with the plain text of the Movie Title.
You can change mismatched movies here:
(Gracenote has more options, but the data is not as complete as data from The Movie DB)
Oh, that's even better than tracking down the correct picture! Thanks!
Edit: I also found another way different. I just bring up the show in TV Shows, the picture has an edit icon and for the one show I had that was off it had four choices. BUT that wasn't one where it was entirely the wrong show. So it might work for your Italian thing, but not my obscure show thing.
You would need to use the Fix Match option and pick the correct show metadata
