MPEG4 issue
I have four custom channel streams that are mpeg4. These are private streams from my company and not open to the public. They have always worked without issue, but recently they either fail to stream or they stop/start and eventually fail. I have no issue watching these directly in my browser. Others in my company are not having any issue with the streams, but they don't use Channels. Any ideas?
2026/07/03 21:59:17.364041 [TNR] Opened connection to M3U-w123 for ch25 w123
2026/07/03 21:59:17.364073 [HLS] Starting live stream for channel 25 from 10.250.1.4 (bitrate=5858kbps)
2026/07/03 21:59:27.390578 [ERR] Probe failed for live stream after 10.026347417s and 0 bytes
2026/07/03 21:59:33.109158 [HLS] ffmpeg: ch25-dANY-ip10.250.1.4-remux: [h264 @ 0x7f82fb808200] Increasing reorder buffer to 1
2026/07/03 21:59:33.134631 [HLS] ffmpeg: ch25-dANY-ip10.250.1.4-remux: [h264 @ 0x7f82fb808200] Increasing reorder buffer to 2
2026/07/03 21:59:33.241037 [HLS] Session ch25-dANY-ip10.250.1.4 started in 15.877065785s
2026/07/03 21:59:33.706534 [HLS] Probed live stream in 338.596319ms: h264 1920x1080 progressive 5114877bps
2026/07/03 21:59:33.717836 [ENC] Starting encoder for ch25 in /Volumes/Media/DVR/Streaming/sessions/ch25-dANY-ip10.250.1.4-852405996/encoder-1-3860298100 at 1 (0.066733) (encoder=remux, codec=, acodec=, resolution=, deinterlacer=hardware, bitrate=10000, segment_size=0.01)
2026/07/03 21:59:33.778963 [HLS] ffmpeg: ch25-dANY-ip10.250.1.4-1-----10000-0--0-0--hardware-false-false-0.01-0: [h264 @ 0x7f935780a000] Increasing reorder buffer to 1
2026/07/03 21:59:33.804543 [HLS] ffmpeg: ch25-dANY-ip10.250.1.4-1-----10000-0--0-0--hardware-false-false-0.01-0: [h264 @ 0x7f935780a000] Increasing reorder buffer to 2
2026/07/03 21:59:33.848958 [HLS] ffmpeg: ch25-dANY-ip10.250.1.4-1-----10000-0--0-0--hardware-false-false-0.01-0: [aost#0:1/aac @ 0x7f935ab0c180] -enc_time_base -1 is deprecated, use -enc_timebase demux
2026/07/03 22:00:35.518101 [ENC] No segments have been generated in 20.100216502s. Stopping transcoder.
2026/07/03 22:00:35.621113 [ENC] Encoder stopped for ch25 in /Volumes/Media/DVR/Streaming/sessions/ch25-dANY-ip10.250.1.4-852405996/encoder-1-3860298100 after encoding 1 to 34
2026/07/03 22:00:35.975988 [HLS] Probed live stream in 354.190685ms: h264 1920x1080 progressive 5278147bps
2026/07/03 22:00:36.000026 [ENC] Starting encoder for ch25 in /Volumes/Media/DVR/Streaming/sessions/ch25-dANY-ip10.250.1.4-852405996/encoder-35-3789755168 at 35 (33.800433) (encoder=remux, codec=, acodec=, resolution=, deinterlacer=hardware, bitrate=10000, segment_size=0.01)
2026/07/03 22:00:36.063429 [HLS] ffmpeg: ch25-dANY-ip10.250.1.4-34-----10000-0--0-0--hardware-false-false-0.01-0: [h264 @ 0x7f9e63814c00] Increasing reorder buffer to 2
2026/07/03 22:00:36.119844 [HLS] ffmpeg: ch25-dANY-ip10.250.1.4-34-----10000-0--0-0--hardware-false-false-0.01-0: [aost#0:1/aac @ 0x7f9e62016600] -enc_time_base -1 is deprecated, use -enc_timebase demux
2026/07/03 22:00:44.843437 [HLS] Stopping transcoder session ch25-dANY-ip10.250.1.4 (out=36.124733s finished=false first_seq=1 last_seq=40)
2026/07/03 22:00:44.845381 [TNR] Closed connection to M3U-w123 for ch25 w123
2026/07/03 22:00:44.875315 [ENC] Stopped encoder for ch25 in /Volumes/Media/DVR/Streaming/sessions/ch25-dANY-ip10.250.1.4-852405996/encoder-35-3789755168 after encoding 35 to 38
2026/07/03 22:00:44.875364 [SNR] Buffer statistics for ch25 w123: buf=2%,0%-100% drop=2%
2026/07/03 22:00:44.875385 [SNR] Streaming statistics for ch25 w123: timeouts=8 segment_timeouts=8 playlist_timeouts=0
