I currently am running two instances of Channels DVR. Both are installed on a Synology DS220+ NAS. One is using Docker, but I am considering running both inside of Docker.
Questions:
- What benefits are there be to run both installations Channels DVR inside of Docker?
- What do I need to know about moving my non-Docker install to Docker?
- Can I do an export/import to make creating the 2nd Docker instance easier?
- I'm using ports 8089 and 8189. Does the second Docker container become 8289?
Rob
