Been recording TCM on YTTV for quite some time, now I'm migrating off of YTTV (but not indefinitely) and on to Spectrum. The channel number for TCM is the same for both YTTV & Spectrum, which is as expected (I think!).
Soon my YTTV subscription will expire, so the only valid source will be Spectrum. How will Channels handle this? Will it, for example, attempt to record on YTTV, fail, and then attempt on Spectrum? Or will it abort recording completely when it fails on YTTV?
I could delete the YTTV source, but I really don't want to do that. It's always been working for me, but not for everyone (see 2FA), so whatever I'm doing I don't want to screw up if I have to start over. I'm assuming that if I reactivate my YTTV subscription that my current configuration will just work.
I've researched the possibility of setting TCM as a favorite in the Spectrum lineup and not in the YTTV lineup, reasoning that the priority rules will try Spectrum first. But I'm not sure that's the case when the channel number for TCM is identical on both sources.
