Multiple virtual channels of same show?
Not sure if this is possible, but I want to have 2 (or more) virtual channels of the same TV Show, sorted in season/episode order, but with staggered start times.
For example, if I have 2 virtual channels of the same show, I don't want them to both be displaying the same show at the same time, but don't want them to be random either.
Is there a way to indicate what episode number a virtual channel should start on?
Anyone? Bueller?
The options you see are what's available
Boooo....lol.
Was hoping someone might have some idea of how to make it work lol.
I don't know if this will work and I can't check it myself at this time but what if you simply wait a few hours before you create the second virtual channel with the same show? I would think the second channel will be shifted in time. Like, for example, create East and West feeds 3 hours apart. Maybe. :person_shrugging:
Actually, that seems to have worked! When I originally created the 2nd channel (basically a copy of the first), it was within a few minutes. However, that was about a month ago so I tried again and now the 2nd channel has a different schedule, about 2 seasons behind the 1st channel.
I'm not sure how the server decides to create the initial schedule, but it appears if you wait long enough, you'll get a different starting episode.
