The FireTV devices is functioning great since the last update.
I can tune all of the channels without issue using the HDHR app.
My Android phone app and the web players are the problem. I have tried different browsers with the same results. When I select an SD channel, such 6.2, the transcoder says that it is starting. That is as far as it goes. On the Android app, it says "Playback Failed". On the web player, the "Transcoder Starting" message remains and the circle in the window spins. I eventually close it out. I can tune the HD channels. No problems there.
Here's the web player log:
2019/10/08 19:28:20 [HLS] Starting transcoder for channel 6.2 from 24.172.167.204 (encoder=h264_mediacodecndk, resolution=720, deinterlacer=blend, bitrate=4000)
2019/10/08 19:29:15 [WRN] Buffer for 1058853B ch6.2 is more than 50% full (clients=1, len=16779000)
2019/10/08 19:29:36 [WRN] Buffer for 1058853B ch6.2 is more than 75% full (clients=1, len=25165868)
2019/10/08 19:29:54 [HLS] Stopping inactive session ch6.2-dANY-3aa07bb9d7b4 @ 0s
2019/10/08 19:29:54 [TNR] Closed connection to 1058853B for ch6.2 GRIT
2019/10/08 19:30:21 [TNR] Opened connection to 1058853B for ch6.2 GRIT
2019/10/08 19:30:21 [HLS] Starting transcoder for channel 6.2 from 24.172.167.204 (encoder=h264_mediacodecndk, resolution=720, deinterlacer=blend, bitrate=3000)
2019/10/08 19:31:14 [HLS] Stopping transcoder session ch6.2-dANY-0b147fa21dee @ 0s
2019/10/08 19:31:14 [TNR] Closed connection to 1058853B for ch6.2 GRIT
2019/10/08 19:34:05 [TNR] Opened connection to 1058853B for ch6.2 GRIT
2019/10/08 19:34:05 [HLS] Starting transcoder for channel 6.2 from 24.172.167.204 (encoder=h264_mediacodecndk, resolution=720, deinterlacer=blend, bitrate=3000)
2019/10/08 19:35:03 [WRN] Buffer for 1058853B ch6.2 is more than 50% full (clients=1, len=16777684)
2019/10/08 19:35:29 [WRN] Buffer for 1058853B ch6.2 is more than 75% full (clients=1, len=25167184)
2019/10/08 19:35:48 [HLS] Stopping transcoder session ch6.2-dANY-0b147fa21dee @ 0s
2019/10/08 19:35:48 [TNR] Closed connection to 1058853B for ch6.2 GRIT
2019/10/08 19:36:59 [TNR] Opened connection to 1058853B for ch6.2 GRIT
2019/10/08 19:36:59 [HLS] Starting transcoder for channel 6.2 from 24.172.167.204 (encoder=h264_mediacodecndk, resolution=720, deinterlacer=blend, bitrate=3000)
2019/10/08 19:37:58 [WRN] Buffer for 1058853B ch6.2 is more than 50% full (clients=1, len=16777684)
2019/10/08 19:38:24 [WRN] Buffer for 1058853B ch6.2 is more than 75% full (clients=1, len=25165868)
2019/10/08 19:38:45 [WRN] Buffer for 1058853B ch6.2 is more than 95% full (clients=1, len=31877468)
2019/10/08 19:38:50 [WRN] Buffer for 1058853B ch6.2 is more than 99% full (clients=1, len=33221104)
2019/10/08 19:38:57 [HLS] Stopping transcoder session ch6.2-dANY-fe1c7fefb664 @ 0s
2019/10/08 19:38:57 [TNR] Closed connection to 1058853B for ch6.2 GRIT
2019/10/08 19:42:04 [TNR] Opened connection to 1058853B for ch6.2 GRIT
2019/10/08 19:42:04 [HLS] Starting transcoder for channel 6.2 from 24.172.167.204 (encoder=h264_mediacodecndk, resolution=720, deinterlacer=blend, bitrate=3000)
2019/10/08 19:43:04 [WRN] Buffer for 1058853B ch6.2 is more than 50% full (clients=1, len=16777684)
2019/10/08 19:43:25 [HLS] Stopping transcoder session ch6.2-dANY-bb0798e56033 @ 0s
2019/10/08 19:43:25 [TNR] Closed connection to 1058853B for ch6.2 GRIT
