Recently the NBC channel in Dallas from locast has stopped working. It shows playback failed in the firetv app or does nothing in the web player but it works when using the locast app itself. All other locast channels work fine. Here is what the log shows.
2021/07/21 07:04:07.759793 [ERR] Failed to start stream for ch5.1: Locast: locast 204 No Content:
2021/07/21 07:04:07.796770 [HLS] Couldn't generate stream playlist for ch5.1-dANY-ip192.168.0.231: Locast: locast 204 No Content:
2021/07/21 07:04:07.796770 [HLS] Stopping transcoder session ch5.1-dANY-ip192.168.0.231
2021/07/21 07:04:08.314656 [ERR] Failed to clean up D:\tv\Streaming\ch5.1-dANY-ip192.168.0.231-409156382: remove D:\tv\Streaming\ch5.1-dANY-ip192.168.0.231-409156382\cache\transcoder.log: The process cannot access the file because it is being used by another process.
