As of the last few days, I can’t tune NBC anymore and instead get an error that it couldn’t fetch the playlist. Is this related to some channels changing the way they stream, or simply a temporary issue?
Thanks
Thanks
Hard to say without diagnostics
Should I send log files from the server or diagnostics from the client device? Also, should I PM them or email to support?
Thanks
On the dvr web UI, Support > Troubleshooting > Submit
Done. Thank you
Looks like the error is "504 Gateway Time-out"
This appears to be NBC shutting off their old streaming servers in favor of the new ones which are unfortunately not compatible.
Thanks for investigating. What a bummer, I hope this isn’t a new trend with TVE…
Well that sucks it's the only reason I pay for this thing
