NBC Sports Boston Recording
I had a recording fail to initialize. I tried to remove and re-add the channel. It didn't let me add it back. It doesn't seem to be authenticating anymore. Is anyone else experiencing the same? Any suggestions?
I am on Fios.
I also tried a Hulu subscription. It doesn't authenticate there either.
If you're not running the latest DVR pre-release version, try updating and then rescan the channel.
Thanks. I gave that a shot. No luck. :neutral_face:
What error message shows next to the channel when you select Rescan Channels from the source gear dropdown?
It says: notAuthorizedRSN
If you can login with your Fios or Hulu credentials using a web browser and watch here
http://stream.nbcsports.com/rsn/nbcs-boston
I would submit diagnostics from the dvr web UI.
Something happened earlier this week and I am now getting the same error: notAuthorizedRSN
I updated to latest prerelease and didn't help.
I can log in and view video at the TVE site.
I just submitted diagnostics: 2902e9e6-0fe6-41fe-bc68-56d876a0d515
Thanks
I am having the same issue. Also using Fios and getting the notAuthorizedRSN error. Tried the link and was able to watch the stream on the web.
Couldn't hurt to submit DVR diagnostics after unsuccessfully trying to rescan the channel.
I would, but I'm not in the region to receive that channel. My local RSN works.
Please submit diagnostics..
I sent just now -- I think.
Can confirm this issue. In my case it’s …/rsn/bay-area. Hulu TVE. Same no longer authorized response. Works in web browser with direct link just not through CHannels DVR. Tried updating and rescanning to no avail.
Check for update of version. The new version works.
Fixed thank you developers!
Fixed here as well. Ty
Yes can also confirm fixed. Thank you developers!!
