NBC TVE channels not working
MSNBC has stopped working as of this afternoon. (I was watching it live for a while earlier today.) Also tried CNBC and USA. Both failed.
Tried rescan of MSNBC and submitted diagnostics after failure: b33d0a64-92ed-4a0b-9b92-32421ab3c4d0
Tried rebooting my DVR server. No change.
Error shows up: "anvato: Failed to retrieve content."
I was able to log in and watch on MSNBC web site. Provider is AT&T TV.
Upgrade to pre-release and try again.
Working now with pre-release.
I had the same problem with MSNBC today, with Verizon as provider. Pre-release upgrade fixed it, plus added about 10 additional channels
i have the same issue. how can i get pre release? DVR running on shield tv
Go to the web ui, click the drop down in the version section and select prerelease.
thanks. i cant believe i never notice the drop down smh
Thanks, fixed it for me too. YouTubeTV.
Both MSNBC and NBC TVE are both showing 60fps now so this is a welcome change
I did a quick check of Monday's Nicolle vs today's Nicolle and the bitrate increased from around 3.5 mbps to around 5.5 mbps.
Yes, looks like all NBC Universal channels including USA and Bravo are coming in at 60fps now. I never thought they would do it for their non-sports TVE streams!
If only Turner and Discovery would catch up to the times…
I'm not sure if related, but the audio on my NBC channel is not working but video is good. I'm wondering if a common solution exists beyond upgrading to the latest Pre-release?
I'm on the latest pre-release. My TVE NBC was channel 6000 but only if I enabled Local Networks via TV Everywhere I've somehow lost NBC and only NBC... ?? I re-signed in to Verizon, no login problems, I've reset my server, checked all settings... nothing... thoughts?
This happened to me a couple of weeks back with CBS. It showed up later in the day (like 10 hours later) during a rescan.
Been at least 24 hours since it disappeared.
If you need help you should submit diagnostics and email support.
I just rescanned my TVE yet again, and magically NBC has returned. It just needed your response I guess tmm1... :stuck_out_tongue:
Lost CNBC on ATT TVE.
Downloaded pre-release and re-scanned all channels. CNBC is back
I, too, found this. But it looks like now it's at a higher bitrate -- around 5-6 mbps -- but 720p. Across all NBC channels. Is this happening for anyone else? It looks like it started on August 11.
