@tmm1 Now on 2021.09.16.1925 build. Here is the log for the NBC Boston streaming problem. Still quits after about 16 sec., sometimes recovers for a minute or so but ultimately just quits:
2021/09/16 16:57:37.459408 [TVE] stream timestamps: nbc: start_at=2021-09-16T16:54:55-04:00 current_at=2021-09-16T16:55:31-04:00 end_at=2021-09-16T16:55:43-04:00
2021/09/16 16:57:37.459493 [TNR] Opened connection to TVE-Fubo for ch6000 WBTS
2021/09/16 16:57:37.461751 [HLS] Starting transcoder for channel 6000 from 192.168.1.159 (encoder=remux, resolution=, deinterlacer=, bitrate=6432)
2021/09/16 16:57:38.010823 [HLS] ffmpeg: ch6000-dANY-ip192.168.1.159-remux: [h264 @ 0x2423d57500] Increasing reorder buffer to 2
2021/09/16 16:57:38.125630 [HLS] ffmpeg: ch6000-dANY-ip192.168.1.159-remux: [hls @ 0x2423cc4c00] Timestamps are unset in a packet for stream 1. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly
2021/09/16 16:57:38.346637 [HLS] Probed live stream in 884.337552ms: h264 1280x720 progressive 5325675bps
2021/09/16 16:57:38.576252 [HLS] Session ch6000-dANY-ip192.168.1.159 started in 2.423567134s
2021/09/16 16:58:22.973158 [HLS] Couldn't generate stream playlist for ch6000-dANY-ip192.168.1.159: Playlist has not been updated in 20.093147578s
2021/09/16 16:58:22.973285 [HLS] Stopping transcoder session ch6000-dANY-ip192.168.1.159 (out: 50.133433s, finished: false)
2021/09/16 16:58:22.973707 [HLS] ffmpeg: ch6000-dANY-ip192.168.1.159-remux: [mpegts @ 0x2423cc4600] Dropped corrupted packet (stream = 1)
2021/09/16 16:58:23.319308 [TNR] Closed connection to TVE-Fubo for ch6000 WBTS
2021/09/16 16:58:24.404319 [TVE] stream timestamps: nbc: start_at=2021-09-16T16:55:31-04:00 current_at=2021-09-16T16:56:07-04:00 end_at=2021-09-16T16:56:19-04:00
2021/09/16 16:58:24.404390 [TNR] Opened connection to TVE-Fubo for ch6000 WBTS
2021/09/16 16:58:24.406459 [HLS] Starting transcoder for channel 6000 from 192.168.1.159 (encoder=remux, resolution=, deinterlacer=, bitrate=6432)
2021/09/16 16:58:24.792497 [HLS] ffmpeg: ch6000-dANY-ip192.168.1.159-remux: [h264 @ 0x29fd957500] Increasing reorder buffer to 2
2021/09/16 16:58:24.869604 [HLS] ffmpeg: ch6000-dANY-ip192.168.1.159-remux: [hls @ 0x29fd8c4c00] Timestamps are unset in a packet for stream 1. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly
2021/09/16 16:58:25.408759 [HLS] Probed live stream in 1.001773542s: h264 1280x720 progressive 6144724bps
2021/09/16 16:58:25.516304 [HLS] Session ch6000-dANY-ip192.168.1.159 started in 1.305826041s
2021/09/16 16:58:35.122858 [HLS] Stopping transcoder session ch6000-dANY-ip192.168.1.159 (out: 31.6483s, finished: false)
2021/09/16 16:58:35.123875 [HLS] ffmpeg: ch6000-dANY-ip192.168.1.159-remux: [mpegts @ 0x29fd8c4600] Dropped corrupted packet (stream = 1)
2021/09/16 16:58:35.159635 [TNR] Closed connection to TVE-Fubo for ch6000 WBTS
