In Boston market (not the restaurant) and NBC tve is having issues:
in home (on wifi) i get the first frame and then a spinner. sometimes it eventually starts, often with no audio. when it does start playing it has some buffer, but skipping in it is laggy
out of home (lte) the stream starts faster (with audio) but flakes out to "connection lost" after a short while
edit: and when i watch through the web player, it starts immediately, with audio, for 15 seconds, and then stops. below the player says "remux running 0s"
using iOS app, server on a ds220+ running 2021.09.09.1401
this might show the logs from the relevant time
2021/09/09 10:57:03.400717 [TNR] Opened connection to TVE-Comcast_SSO for ch6000 NBC 2021/09/09 10:57:03.401419 [HLS] Starting transcoder for channel 6000 from 174.196.206.79 (encoder=remux, resolution=, deinterlacer=, bitrate=6432) 2021/09/09 10:57:03.576454 [HLS] ffmpeg: ch6000-dANY-77bfb646f99c-remux: [h264 @ 0x7210600] Increasing reorder buffer to 2 2021/09/09 10:57:03.595683 [HLS] ffmpeg: ch6000-dANY-77bfb646f99c-remux: [hls @ 0x72cc800] Timestamps are unset in a packet for stream 1. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly 2021/09/09 10:57:03.709389 [HLS] Probed live stream in 307.883055ms: h264 1280x720 progressive 5630465bps 2021/09/09 10:57:03.721657 [HLS] Session ch6000-dANY-77bfb646f99c started in 515.410965ms 2021/09/09 10:57:47.478442 [HLS] Stopping inactive session ch6000-dANY-77bfb646f99c 2021/09/09 10:57:47.478518 [HLS] Stopping transcoder session ch6000-dANY-77bfb646f99c (out: 11.9286s, finished: false) 2021/09/09 10:57:47.479357 [HLS] ffmpeg: ch6000-dANY-77bfb646f99c-remux: [mpegts @ 0x720bac0] Dropped corrupted packet (stream = 1) 2021/09/09 10:57:47.480788 [TNR] Closed connection to TVE-Comcast_SSO for ch6000 NBC
edit: have tried a few other channels that dont seem to be showing the problem, (abc, cbs work with TVE, a few other cable channels)
