Hi I just got this service to try and see.
when i am trying to add source tv everywhere i got stuck on verifying log in spectrum
any help?
You have to be patient with spectrum authentication. I may appear like nothing is happening but it takes a while for it to process all the channels. It can take up to 25 minutes. Let it spin. the discovery networks is where it hangs up for a time due to authentication timeout. You will see after the process is complete
Hi Kenny,
Thank you for the information.
I will wait patiently
i will let you know.
hopefully this work for me
i am currently using stremium
Make sure your chrome is up to date, and click the dropdown next to Check for Update and select Prerelease
Hi Thank you for your help!
Like I said i am a new user and i ma trying this and see if works for me.
i still have some issues:
1 when i restart PC is giving me error so i kinda need to reinstall server
2 is still having issue loging to spectrum it got stuck on 61% Fetching missing guide data for 2021-04-25 8:30AM. and is doing nothing.
any sugestion.
Thanks!!
I would delete the source and add it again. I assume the first time you interrupted the authenticate process before trying it again.
Hi,
I dont think this will work for me
too much issue
Thank you very much for your help
not getting all the channels i get from spectrum
Are you getting any. If you talking about the discovery channels then there is a trick to get those working.
Hi Kenny,
i only have 10 channels plus local on spectrum
and i am getting only tnt tbs cnn thats all missing espn 1 and 2 fs1 nfl nick locals bein sports
